4.0 major problems
rathranger
I have a 96 4.0. it's idling around 700 and jumps around alittle. it seems to be burning oil and is misfiring really bad. when i hit the gas it won't idle up and sometimes dies.but it will run like this for a few minutes then be fine.
I am not driving well doing this just sitting in park. also sometime it will be idling fine but then just die.
HELP!
birdman
is your engine light on?
Mine is doing the same thing and has been for a few weeks. but mine only does it when its cold outside. I first changed the IAC, didnt help, and now my computer is saying EGR so i have to change it, if its not that then i thin mine is then fuel rail gasket
rathranger
yes CEL was on showing P171 and p174. running lean in bank 1 and 2
rathranger
i ran the truck today, i can make it idle up if i go real slow with the pedal. it seems to be blowing out a lot of black. my exhaust tips are black, and so is the snow bank i'm parked next to. i don't know if this is excess fuel or oil. I have some problems since i got my programmer im not sure if this would be from that?
Rudie Del Rude
Pull your plugs and see if there's oil on em. If you find some with oil on em pressure test those cylinders to see if its a head/gasket or ring leak. If not it could be your valve seals or maybe a really bad intake manifold gasket leak.
