- Aug 31, 2021
- Reaction score
- 974
- Location
- Roanoke VA
- 1997 and 1999
- Make / Model
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Ah well that's what I get for making assumptions as to why you had the air. I got to finish your build thread. Air sounds great to have though.
Did not realize this problem of the pinion diameter, thanks. How about 4.56, same problem, or just less of it? There are others in between my 3.73 and 4.56 but at some point if it's just a tiny change it's not worth it.
Any reason I'd want to go to 4R70 trans? I'm guessing firm no because lots of work and the 4.0L would never come even close to over-torquing the 4R55.
I had to go a couple places this evening and pretended I had Aussies, how would I drive and found you are of course correct what you say. Probably it's like, I drove stick for decades, went to auto, found myself reaching for stick that wasn't there, but in short order that goes away so driving w/ lockers of that type probably becomes natural and instinctive pretty quickly.
Only place I wondered about is, I was in a line for Rx pickup (heart meds), pretty sharp curve, but inching forward I just keep my foot off the gas completely, and was wondering, is that small amount of power enough to lock them up, I'm guessing yes but situations like that maybe you only find out after you have them.
For turns in town (not talking about at intersections, just curvy road) almost always the steering wheel is moving only 10 to 20 degrees from its tdc which is not a lot of steer, rear tires probably would not drag under power. Again a guess.
I will check out the more expensive ones just so I have the complete picture but what I get from your post is probably the Aussies are fine and yes simpler is better for sure, reduce the points of failure. And they're not pricey... it's the work involved putting them in correctly. Ratio change is somewhat pricey, but if one is doing it you'd want to do them both at the same time. Don't have to, though. I could put manual hubs and lockers and 31" tires and call it done for a while and I might be real happy with that.
Thanks again and I'm figuratively taking a big breath.
