4R55E tq converter have a drain plug?
Shotokan1509
CT
Need to replace the pan gasket on my 4R55E due to leaks, figured I should do a full trans fluid flush but some say there is a drain and others say there is not on the tq converter for my truck. What's the correct answer?
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
Muscleford
Streetsboro Ohio
4.0 SOHC
So basically you use the transmission to pump itself clean.
How do you get the trans to pump itself clean? Run it with the pan off and let it fall into a pan?? Somehow that doesn't sound like the right thing to do.
Thanks
George
mjonesjr
Firefighter
13
Salem, IN
Thanks
George
Did you read the PDF link I posted above? I would assume you haven't since you don't know how it works. Please read the link posted above to answer your question.
Muscleford
Streetsboro Ohio
4.0 SOHC
Sorry I didn't see the link in your previous post.
Thanks good info.
George
Josh B
1,986
Oklahoma
that link don't work
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I disconnect the trans outlet cooler hose from the radiator and connect some clear hose to it. With the hose ran into a bucket I crank and run the vehicle for 10 seconds then shut it off. Refill with fluid and repeat the process until bright red fluid comes out. I have done this many many times with good results.
Josh B
1,986
Oklahoma
I've recently become the owner of a somewhat unhappy 4R55E, and been reading a lot of old catchup (I wonder if that wriggly line would disappear if I spelled it ketchup)(it did) threads.
There are a lot of old threads having links with no destination, but I think this was the first one where the OP had scolded someone for not having clicked it ;)
Josh B
1,986
Oklahoma
Unless it's got contaminated or burned oil, there's really no reason to do a complete flush is there?
Craig0320
225
Mississppi
You answered your question on this one.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Transmission fluid is red.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Not when it is green.
Then it's green and not red.
Sometimes it's purple...
Blue even.
