#6 plug wet
Ranger Phil
Hopewell, Va.
#6 plug seems to be fouled with oil. Engine smokes bad. replace plug and it stops for about 100 miles then it starts again. have replaced the head
(used) and it still does it. replaced coil, dist. cap and button, and wires with no change. compression is 170. questioning the ICM. any help will be gratefully accepted!!
Phil
graff104
Oklahoma
Whats the compression on the other cylinders?
Ranger Phil
Hopewell, Va.
150 is lowest 170 is highest
krustyguitar
check for leaky injector on that cyl
Ranger Phil
Hopewell, Va.
the injectors seem fine. they are all clicking while running and ohmed out at 15.3 to 15.6.:icon_confused:
shadetree
9
East Texas
Explorer Sport
If it smokes constantly, it is probably a broken ring. Oil is coming from the crankcase not the ICM. You replaced the head, so that eliminates valve guides/seals.:)shady
betomonroy
San Antonio, TX
No doubt... its either a broken ring or an oil leak through the head gasket due to an uneven surface.
