8.8 swap problems!!!
djschick88
Tyler Texas
4 Cly
Heres the story:
Problem #1: I just swapped an explorer 8.8 into my 95 ranger and i bled the breaks when the swap was complete and when i hit the breaks theres hardly any stopping, but when i hit them a second time its a little more firm and if i hit them a third time it is perfect...
Does this mean i didnt get all the air out of the lines or does it have to do with the drum to disk swap when i put the 8.8 in??
Problem #2: I swapped in an explorer 8.8 with 4.88 gears into my ranger and now i have some problems.
In 1st, 2nd, and 3rd gear nothing seems different but when i get into 4th there is a sound when i let off the gas and coast still in gear. In 5th the sound is always present when in gear accel and decel. If i coast in neutral it goes away.
I am certain i got the pinion angle correct, but if it sounds like i didnt let me know because its my DD and i need to try to correct the problem.
Thanks
-DJ
t0x1k
9
Somerdale, NJ
3.slo
Did you bleed all 4 brakes starting from rear pass side up to front diver?
ecablarn
Michigan, Bay County
Ford / Ranger
302 V8, Mild Frame off Restoration still have bodywork
Leveling 2" Lift
31x10.5xR15
BSME, design, drawing
^^ This. You need to bleed the brakes again it sounds like
dla
Air in the lines would'nt feel "perfect" - it would feel mushy. Sounds more like you didn't pump out the calipers before you started driving. And your "hardly any stopping" refers to the rears - right? You've got a split brake master cylinder and what you do to the rears doesn't effect the fronts, unless you run all the fluid out.
djschick88
Tyler Texas
4 Cly
I bled from pass rear to driver rear then pass front then driver front.
I had someone pumping the breaks to get the air out should the "pumper" hold the pedal down when i tighten the bleed valve. or push and let off?
dla--- How would i go about "pumping out the clipers"? And im not sure if its just the rears i would think it is... when i swapped the rear end out a lot of fluid came out one night when i forgot to tilt the nose of the truck down to keep the fluid in the lines. Im not sure how much came out though... The resivour is full and i have tried to bleed the breaks twice now.
dla
The very first time you apply the brakes, the rear calipers have to fill up. This will cause your peddle to hit the floor and your reservoir level to drop. Once the calipers have filled your peddle will feel firm. You'll need to top off the reservoir. The calipers only need to be "pumped up" once. If you have mushiness in the peddle afterwards, you have air in the system and/or a leak.
When you bleed the system, be generous. Sometimes you can have an air bubble further towards the master cylinder that will require passing a couple oz of fluid to clear.
Guilius
Millbury, MA
When you Bleed the brakes and the person helping pumps the pedal and holds it down, you crack open the bleeder then tighten it back up before they let off the petal.
if they let off the petal before, your getting air back into the system.
best way to do it is to just relax with a 12 pack....open all the bleeders and watch them drain and fill the reservoir when it gets a little low......and just let it drain.
now this is time consuming, but the best method.
i have never had a problem with the pedal pump method, as long as it is done correctly.
djschick88
Tyler Texas
4 Cly
Alright ill have to give it another shot. I have done it once before and had no problems but i guess i did it right the first time (beginners luck). Thanks for everyones input and help... Ill post back if i get it or not.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Buy one of the Hand Vac Pumps, you can do the whole job by yourself if needed.
Get extra brake fluid and go for it and don’t let the master run too low.
As stated start on the pass’s rear, then the driver’s rear, pass’s front and driver’s front.
luck
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Does it have drums brakes ?
djschick88
Tyler Texas
4 Cly
no its all disc
