85 Ranger getting some teeth...
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
I noticed a ton of 5.0 Explorers at U-Pull-It last weekend, how does their setup work with no A/C or smog pump?
Yes, you can re-configure it like that (no smog pump anyway). Even cut the bottoms off the brackets if you like.
Remember, they require the specific PS pump, Alternator, timing cover, water pump, and balancer/pulley (it's one piece).
If you get rid of the AC compressor, skip that upper idler pulley, too.
'94/'95 Mustang FEAD would allow you to use your current alt and AC pump and balancer. It uses the same timing cover as Explorer, and is almost as short. You would need the brackets, water pump, timing cover and crank pulley.
18,011
SW Iowa
Gaa, I don't want to change all my accessories though... I didn't look at them very close.
I dunno, I might just suck it up and stick a new pump in it...
18,011
SW Iowa
Well I got the water pump changed, got an exhaust put on it and as a whole it doesn't go too bad.
It goes like a bat until just under 3k, then it seems that cylinders just seem to take turns firing. I back out of the throttle and they come back online. If I ease into it more it doesn't want to do it as bad. Rewatched my video that came with the carb and it went with my running theory it may be a fuel delivery problem.
It has a new filter on the fuel pump (came with the pump, it screws into the inlet), and a new filter (bigger one) near the carb.
Am I overfiltered? Under fuel lined? (roughly .25" nylon from the 2.8) I have .25 barb splicers to take it from nylon to the hose barbs that the fuel pump takes.
It has been awhile, '87 roller non HO 302, Edelbrock 1403 500CFM carb, Mr. Gasket electric #12S fuel pump.
kimcrwbr1
46
maplevalley WA
2.8l
How do you have the timing adjusted. You need to adjust for total advance around 38 degrees btdc at 3000 rpm. Advance the timing until it pings under a load above 35 mph then back off until it dont ping and adjust the idle air for the highest vacuum pressure. You need to sync the fuel delivery with the timing and ford engines like to be advanced as far as possible without pinging. Every time you change the timing you need to adjust the idle air for either highest rpm or vacuum pressure. If you have vacuum advance use manifold vacuum not ported off the carb just plug the carb ports. So advance the timing a couple degrees at a time until it pings and back of a degree at a time until it stops.
baddad457
18
Opelousas La.
Is there a filter in the carb inlet fitting ? And where is the pump mounted ? It's been a2while since you started this, I don't recall what pump you're running. The size of the fuel line isn't likely to be an issue, it doesn't take much fuel to keep a carbed motor well supplied with fuel, even at WOT. I've run a 4.3 V6 in a boat under full load (18" ski boat) using a portable steel fuel tank with a Merc quik disconect fuel line.
18,011
SW Iowa
Inside the driver side frame rail, right in front of the fuel tank, at an angle per the instructions.
No filter on carb inlet, but I have a wix that fit the fuel line right by the inlet.
Mr. Gasket #12S pump.
I might play with the timing some more, kinda wonder if the advance isn't messing with me after kimbcrwbr1's post.
kimcrwbr1
46
maplevalley WA
2.8l
From what your saying about loss of power on the upper end If you know the float level is good I am guessing the carb is plug and play, you need to establish the total timing at 3000 rpm and then adjust the idle air engine idle at 750 rpm and max vacuum pressure then check the idle air screws are within half a turn between them. Count the turns in then back out from lightly seated. As long as you have enough fuel pressure 5-7 lbs it will give you enough volume just look at how small the input port is to the float valve. You may need to adjust the high speed jet size and the best way to do that is on a machine. Total advance is the way to go on the upper end performance the lower end will take care of itself.
flaminranger
washington (the state)
2.0
if the carb is adjusted correctly and the timing is correct. then if it still does it I would look into the fuel volume. you may have enough pressure but not enough volume. some of the smaller electric pumps can not keep the float bowls full.
also check your the float level as well. if it is not adjusted correctly when you step down and open the secondaries there might not be enough gas in the bowls to use.
have you tried upping the jets yet?that could cause a lean miss.
baddad457
18
Opelousas La.
The pump he's using has enough volume to suppy three carbs at WOT.
baddad457
18
Opelousas La.
Did you install a filter inline between the tank and pump ?
18,011
SW Iowa
There was a little one that screws in the outlet of the pump (that came with the pump) and a I put a inline near the carb.
I haven't set the carb much yet aside from the idle, if anything it should be too big and need jetted/rodded down. In my experiance too big = bog which this doesn't do.
kimcrwbr1
46
maplevalley WA
2.8l
Do you have your vacuum advance hooked up to manifold vacuum what kind of dizzy and have you advanced the timing until it pings yet.
baddad457
18
Opelousas La.
You need a filter between the tank and pump to protect the pump from being clogged with any trash that comes out of the tank. A 600 Edelbrock shouldn't be too big. Now however if the secondary side isn't supplying fuel, and the secondaries open, then you will get a fuel starvation problem. Don't know if that's possible with an Edelbrock though, it can happen with a Holley. I think I'd run it hard til it does, then shut it off and immediately pull the top off the carb to see if it is running out of fuel.
18,011
SW Iowa
The filter is on the pump inlet side, that is what you get when you bend over and look at it upside down. :D
Carb is a 500cfm.
I got dad to help with the timing, runs great for now. I will do some more fine tuning with the carb but it is pretty close right now.
baddad457
18
Opelousas La.
Or look at it in a mirror ? :D Glad to hear y'all got it straightened out.:icon_thumby:
