93 2wd 3.0 conversion to v8
Nerdnick
279717
Ford ranger
Hey everyone,
I know this will most likely be a repeated thread and question but I’ve spent nearly all day and haven’t come across a direct answer
I’m wanting to do a 5.0 swap on my 93 2wd 3.0 but I can’t seem to find a direct branch year for the explorer I should be searching for.
I would like to stay EFI as well as retaining a/c and all functions but essentially want to build it into a prerunner/project truck
Threads or links would be highly appreciated for this is all new to me
Thanks
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I would think a 96 to 01 would be the best donor, especially if you can find a 2wd Explorer which would be hard to do if you were in NH.
Nerdnick
279717
Ford ranger
Awesome I appreciate it. Will I need to do an oil pan swap starter relocate or anything else just like the 2.3?
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I suspect not but I'm not sure, the chassis in the Explorer is Ranger based.
Nerdnick
279717
Ford ranger
Thanks bud I appreciate the response
captaingofast
I have a `96 Explorer 2WD V8 auto and a `96 2WD Splash auto that I'm doing a swap with. From what I can see and what I've read the 96 Explorer is a 96 Ranger from the cowl forward. Or vice versa I guess. I have another 5.0 long block I'm using instead of the donor V8 but I'll be able to use everything else like engine accessories, intake, computer, radiator, transmission etc in my Splash. Took quite a while to find a 2WD V8 Explorer. They're not exactly plentiful around here (southern Ontario).
Nerdnick
279717
Ford ranger
So is it not possible to do the swap or what all is required? Because I was looking into doing a 96-01 5.0 explorer as well but I would pull motor trans harness and all
