96 4.0 Explorer XLT 4x4 Getting it back on the road
Josh B
1,987
Oklahoma
On a positive note, I live on some rough country roads, travel some rough highways, and the cheap-ass shocks are working great ;)
Josh B
1,987
Oklahoma
Damm this thing has me stumped! All I did was swapped the PCV, coil, and plug wires.
Suddenly there's a horrific miss??
I've swapped the wires back and forth twice (also the coil), been over every inch of it with a fine tooth comb a dozen times, sprayed carb cleaner all around while it was running, absolutely no clue
Engine code reads P0401
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
check the vac line on the egr
Josh B
1,987
Oklahoma
I sprayed carb cleaner on it and checked the line, it's got a vacuum on it, not a strong one really but it seems to be working. Reckon I should swap that with the 93 and see?
Nope! That's all different. Reckon it needs a valve?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
do you have a vac gauge? if you dont...get one. see what the engine is doing. could just be a stuck egr valve or sensor somewhere.
Josh B
1,987
Oklahoma
Thanks Bobby, I'll get one
Josh B
1,987
Oklahoma
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
That will work fine.
Carberator engine fuel pumps rarely went more than 7psi. 3 to 7 was a normal range.
Josh B
1,987
Oklahoma
I noticed that in the instructions Always, they're directed only towards carberation
Josh B
1,987
Oklahoma
Leave to parts places to make things all complicated.
First I went in at AutoZone and they didn't have a vacuum tester had to order it, $20. I saw the photo, looked like a round tire pressure gauge with an extension hose on it. Won't be in till Tuesday but it's already paid for(for now)
Stopped later at Oreilly's and they found one on the shelf, $28 but looked like a much better tester, and it also does fuel pressure.
After getting home and studying in to it I found the fuel gauge only goes to 10lbs, and only discusses carburated applications.
Isn't EFI more in the 40+ lbs range?
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yes, Efi is in the 20 to 100psi range. That needs a totally different tester. I pick one up at Princess auto that goes to 300? IIRC. With adapters so it does diesel too? My memory isn't good and I haven't looked at it a couple years.
Josh B
1,987
Oklahoma
Also need to add that whatever has been changed that thing seems to be devouring a tank of gas :/
Thanks Always, guess I'll wait for the vacuum gauge on Tues :/ I haven't opened this one yet till I knew for sure, so I can still return it
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
testing the vacuum is a great tool. with a perceived miss it can help
efi is usually hi psi and requires a different testor.
snoranger
Professional money waster
ASE Certified Tech
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You have the egr and the fuel pressure regulator vacuum lines switch.
Josh B
1,987
Oklahoma
Thanks Bobby, I took the O'really's back and will wait on the simpler AZ one, should be here Tues. I didn't see me needing the carburetor version
