- Feb 28, 2001
- 4,368
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
I have a '97 Ranger that I got cheap, previous owner was a ditz and replaced the drivers door with a white one, the rest of the rig is the kinda candy red, don't know if there were more than one red in '97... Anywho, going to the junkyard in a couple weeks to hopefully find a red door with a door panel (how that ended up missing I don't know, didn't think to ask for some reason) among a whole list of small things. If I can't find a door, are there any rattle cans that are similar color?
If I got a door that had a power window (currently has manual) could I either just put power and ground to the door wires or swap in the manual regulator? I imagine swapping the geartrain is a pain but doable, and as long as most of the circuitry is in the door just wiring it up should be simple enough, at most it might take a relay or two.
Ok, I'll stop rambling, thanks for any help.
