99 b2500 2.5L
Hendog 80
Summerfield, FL
Ford Ranger 2.5
Had a wiring mishap on the wirers that come from truck bed to the new aftermarket fuel pump assembly. The wires at the wiring harness were melted. I had to cut it off in both sides ( F/P & TRUCK SIDE). I look at the colors of the wires to make sure they would go together with ease. Right this is a month later and still no truck.
So what I need is to find out the which color wire from the F,/P goes to which to color wire from under truck bed?
I also am have Ming a problem with the F/P staying on without the engine on just the key. It does not shut off after the 2 second time.
1999Mazda Central Florida
10
Mazda
Michelin LTX M/S P235-75R15
Have you found the issue yet with wiring? My brother just went to Summerfield this past week. I'll be under my truck tomorrow (changing the brake hubs.)
I'll check and see if I can visualize the wire bundle and pump if I can. I need to get one of those bore-scopes to remotely see things.
Hendog 80
Summerfield, FL
Ford Ranger 2.5
Go to the passenger side of the truck crawl up underneath to about the drive line and then look up and lay on your side facing the gas tank and when you look up you can see the actual fuel pump you can reach your hand in there with your phone and take a picture if you would that be awesome man thanks !
10
Mazda
I'm going to Wildwood today (noticed Summerfield is right North of Wildwood.) I'm in Mt. Dora. Getting some pics was harder than expected, but hope it helps.
One of these days if I upgrade my cell I'm going to get one of those borescopes (no excuse not to have one except my older cell will not take the app. that's needed for it.)
Inspection bore-scope <--click here
It will take videos and snap-shots. A definite Christmas gift request ?
Take it easy,
R.S,
No members online now.
