If its a "circuit" code that means its a wiring or Solenoid issue
But I have
Code 89 A4LD - Converter Clutch Override solenoid - Transmissions
or
AXOD Torque Converter Control solenoid circuit - Transmissions
or
Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
Same codes were used for multiple vehicles and mean different things
In a 1988 A4LD there are 2 solenoids, TCC(converter clutch) and 3-4 shift(overdrive)
There is a 3 wire connector on drivers side of trans
Center wire will have 12volts with key on, it powers both solenoids
Each outside wire runs back to computer, the computer GROUNDS that wire to activate that solenoid
Since a solenoid is just a coil of wire, when key is on the computer should see 12volts on each of those "ground wires"
If computer does NOT see the 12volts it will set a code for that
You can use an OHM meter between center pin on trans to either outside pin to test if solenoid has a full circuit, you should see 26 to 40 OHMs, if not then solenoid or wire inside trans is bad
The TCC locks the torque converter to engine RPMs, the computer uses engine RPMs and Speed to test if the torque converter is locked
RPMs and speed should change at the same time when torque converter is locked, no delay when accelerating or decelerating, no "slipping"
There are pressure test ports on the outside of the transmission, these can be used to narrow down what might be wrong
The image has lots of info:
https://www.explorerforum.com/forums/media/a4ld-specification-chart-from-transgo.39537/full
But I think the 1988 was first year of the 2 solenoids, not 1989, but yours may only have the 1 solenoid, wouldn't matter for Reverse or troubleshooting
