A4ld transmission nightmare
Chuckc
Florida
Bronco ii
So this 1988 bronco ii has been a nightmare for me but anyways here’s my issue now. A4ld automatic 4x4 had water in trans and had engine issues once I got engine running good flushed milky trans. Went to put in reverse one day and locked up. Would go in overdrive and tires seemed to spin decent in drive also. Dropped pan found metal and milky oil also found plastic seal in pan. So removed trans took completely apart and found springs retainer on forward drum popped off and tore up bushing exc. replaced forward drum put new clutch packs inspected everything put back together re installed and still have issue... it will go into reverse and tires spin for about one second then locks up. Overdrives seems to work perfect and drive and low gears work but might be a bit sluggish.. please help possible solinoid valves or something? Pics are from before rebuild still haven’t dropped pan again getting tired of messing with this
franklin2
1,768
Virginia
Never did much serious work on a automatic trans, but from what I am told, it's very difficult to perform surgery on a automatic and be successful. Once something fails, the bits and pieces and contaminates are circulated throughout the whole trans AND the trans cooler in the radiator. So a complete rebuild is usually required, and a thorough flush of the cooler lines and cooler, or replace the radiator entirely.
I did a c4 swap once long ago. Torque converter had some damage to it so decided to use the old torque converter from the old trans. Bad idea. The trans I swapped in failed in short order. Found out the old torque converter sent little metal bits all through the newly swapped in trans, it started making a buzzing noise and would not operate in reverse.
I am guessing you have contamination in your valve body causing your valving to stick. That's just a guess though.
Chuckc
Florida
Bronco ii
Yeah that’s the direction I was going next maybe swapping out solinoid valves and try cleaning valve body again.. used about a can of brake clean and compressed air last time. It does make a bit of a buzzing noise and I did re use torque converter.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The a4ld only has two solenoids. The torque converter clutch and overdrive. Neither effect reverse.
My advice is stop messing with it and replace it. You had major fluid contamination, broken parts and metal floating around in it. Chances are it needs a total overhaul which means new pump, sprags, converter, possibly drums, and a valve body rebuild and not just a soft parts kit like you did.
Not trying to be sarcastic or a jerk, just trying to save you from going further down the rabbit hole. Even buying a "rebuilt" transmission is sometimes a nightmare because they only replace soft parts (clutches bands and seals) when these transmissions often require a full overhaul.
