adjusting driveshaft/pinion angles
clifford97
4
north jersey
my ranger is starting to sag in the rear, the leafs are pretty much sitting flat. so to counter that i went out and bought a set of chevy lowering shackles, but i also want to swap a set of explorer leafs since they're probably stronger, thicker, and will have more arch than my old ones. but im worried that it will throw off my driveline angles and cause problems. also if anybody knows how to measure them with out special tools or what i would need to get it right. thanks:icon_thumby:
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I'm running the stock pinion angle on my 91 with 5" of lift in the back of it...zero problems.
Stxrangerbumper
Ontario, Canada
B2300 / f250HD
v6 3.0L/ 7.3L
the first pinion angle is alway better to be as straight as possible, but if has an angle of minus than 10° deg her should be good
and front, its that I can not exceed the 3 deg (4x4)
We intend to argue there exist The degree shims to
axle shim deg
clifford97
4
north jersey
:icon_bounceblue: cool, yea i forgot to mention i already have a 4'' block kit on it already, but its more like 3''. but thanks for in info, ill let everyone know how it works out :D
No members online now.
