- Jul 20, 2008
- Reaction score
- 3
- Age
- 34
- Location
- reno/sparks Nevada
- Make / Model
- Mazda
- Engine Size
- 4.0
- Manual
oh, that makes sense nowIs your D44 a Hi-Pinion? If so, that's why.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
thanks for the info, whats the method for using the digital caliper for pin ion depth?ive run richmond, motive and yukon and never noticed a difference between any of them.
also the "pinion depth tool" is your digital caliper, which also is used to measure your shim packs.
you have to take the 4nuts off the retaining plate, then pull the shafts out a little bit, then you can pull the 3rd. Also the way you use the digital caliper to measure is when you slide the caliper open it has a little "pin" that slides down, you PUt that on the face of the pinion and measure to the centerline of the diff. Distance will be displayed on the digital display.also can anyone tell me, if i can just pull the center chunk out of the 9 inch or do i have to pull the axleshafts out and pull the axle apart?
oh, thanks, now theres one less tool i need to buy.you have to take the 4nuts off the retaining plate, then pull the shafts out a little bit, then you can pull the 3rd. Also the way you use the digital caliper to measure is when you slide the caliper open it has a little "pin" that slides down, you PUt that on the face of the pinion and measure to the centerline of the diff. Distance will be displayed on the digital display.
really you need a bearing splitter. You can get those just about anywhere, I wouldnt worry too much about quality, they are hard to break. and yes internals will swap between carriers.oh, thanks, now theres one less tool i need to buy.
how about bearing pullers? where should i look for those? i saw some on ebay not sure if there good quality though.
also, i was wondering if i could buy a bare open carier for 3.92 and numerically higher and put my old internals from my old carrier in it?
