Another 1st gen
Dan B.
January 2012 STOTM Winner
MTOTM Winner
22
Armagh, PA
387 Windsor
The keeper of the bunch. Told my boy we should name it Harley since it burns gas, shakes and makes very little power.
33362
Started on some of the small things that need addressed. the driver side door doesn't close properly...needs hinge pins and the striker plate possibly adjusted. Colt (my 14yo son) will be doing most of the minor mechanical and cosmetic work. It does not really need anything major.
33363
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
Update.
The nasty old grill badge was bothering my son...so I gave him one that was hiding in my toolbox.
33966
Hinges are rebuilt, door panels are swapped for a set from a grey 1989.
33964
Also got the exhaust installed. This Borla has to be sad. It used to live and make fantastic sounds under a GT500KR. Now it's under a Ranger.
33962
It's running well now. Found a vac leak in the line connected to the MAP.
33961
Found another at the EGR....take note....tape is NOT a good way to seal a torn EGR gasket or to make up for the wrong bolts! ;)
33954
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
hmmm.....kr 500?
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
And.....a step backwards. Heard a whistle start and the idle was higher than normal. Chased it with carb cleaner and seemed to be coming from the middle intake gasket. Pulled everything apart, gasket looked good. But will throw a new one in, check the other vac lines and reinstall.
33989
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
Still chasing the fast idle issue. Cleaning the TB didn't do it. IAC is next.
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
Tired of chasing the high idle...switched to floor pan repairs.
