Anyone using a Melling 328 high volume oil pump ?
Connecticut unfortunately.
351W , 2.9L , 4.0L
I purchased a Melling 328 oil pump for my 2.9.
The box says 328 but the marking on the pump reads 128 ?
Anyone else notice this ?
alwaysFlOoReD
5,142
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I can't help. All I can suggest is to phone the company tomorrow morning. My respect for the company dropped a notch a few months ago when I found I had to grind the bolt mounting surface to parallel the block mounting surface. That was on a 460ci.
351W , 2.9L , 4.0L
I asked a member here , BrutalPanda who recently posted that he was using one says that he contacted Melling who told him its the same case but different gear ratio.
I was thinking that may be the case but wanted to double check.
3,614
That would make sense. The case isn't going to change, so it would be a huge production expense to have a second casting die just to change the case number. But the gearing inside the pump would be what changes the flow.
BrutalPanda
5
55 psi at idle when cold. 30 warm, I'd have to say its safe to say the rep didn't bullshit me cause I was skeptical at first. It took 10 seconds of priming to have oil out of the rockers
Sent from my XT1565 using Tapatalk
truckerdawg
5
GA via NC Mtns.
4"
31X10.50
The 3 I have bought all had 328 on the pump -not 128.
