Big problem. Dead engine?
Bryan22
4
So-Cal babay
94 extd
94 2.3
I just bought a 92 3.0 for a work truck. besides the usual problems when buying a used truck, the truck has been good for the most part.
Then yesterday i was driving down the road and it just died and wouldn't start. I checked to see what was wrong after towing it, and it had no spark. So i tested the coil, which was borderline on secondary resistance and replaced it hoping it to be the culprit. Nope.
Then i had someone turn the truck over with the cap off the dist and noted no movement on the rotor. So out comes the distributor. Now i see that the gear is about 1/2 sheared. Not a good sign. I pulled the gear off and put the shaft back into the hole and tried turning the oil pump. At first very easy and smooth then it started building resistance. i believe the oil pump seized causing the gear to shear, which lead to the no spark situation.
Basically i'm figuring it needs a complete rebuild since the oil pump appears to be what caused all the havoc. Anyone have any advice or experience in this particular situation?
Big Jim M
30
Austin
Hold up there!
Turning the oil pump by hand will build up pressure to the point that you cannot turn it any longer..
There is a shear pin in the dist that usually shears when the pump fails.. I don't know of a pump that has failed and yet still builds pressure.
A sloppy, well worn distributor can cause the gear to shear all by itself.
Chances are HIGH that the camshaft gear is now of no value and will need to be replaced. HOWEVER I have seen several that tolorated such a mishap and continued in service.
I'd be for putting a magnet into the hole and seeing what came out. You may get away simply by installing a different dist from a junk yard..
Big JIm:hottubfun::wub:
Bryan22
4
So-Cal babay
94 extd
94 2.3
hmm, that's food for thought. I was on the same line of thinking with the cam gear though. I'll take your advice and let you know what happens. thanks.
-edit- also there was a small groove in the dist shaft, but i didn't think it was anough to break a gear like it did. deep enough to catch a finger nail though. -edit-
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
653
Central Indiana
I agree. Usually the cam gear goes first, which causes the oil pump to stop. Atleast that's what's common on the newer distributorless 3.0's.
