Boxing/Plating Frame
Speedaddict
Georgia
3.9L
Currently working on my 98 Ext Cab Ranger. Under the knife getting D70 /D60 w/4bt
The front half of the frame is already boxed, I want to finish boxing the rear and plate some on the front. My question is how much is too much?
I will be towing a smallish 2 axle camper and playing in the swamps. I want strength and reliability but worried I will go overkill on the plating.
Any advice and tips?
Indiana
I would think stiffer is better, that way any articulation is in the suspension rather than the frame. All depends on what you want the truck to weigh lol
Speedaddict
Georgia
3.9L
Not at all worried about the weight. Cummins and 1tons eliminate that option!
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Are you putting in a cage?
Speedaddict
Georgia
3.9L
No cage, I don't rock crawl in South Ga. Nothing but mud.
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I don't know too much about this subject. If you aren't twisting up the frame, which I guess mud doesn't, then maybe you don't need it?
The reason I asked about a cage is that stiffens the chassis a lot, probably more than boxing the frame does.
Good luck in your search for answers, sorry I couldn't help.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I like to over engineer things. But if you're going to be in a lot of mud and water, how will you clean all that out of a boxed frame so that it doesn't retain moisture and accelerate rust?
Just something to think about.
This message composed solely of recycled electrons. Go green!
Speedaddict
Georgia
3.9L
As far as mud or sand in a boxed frame goes, no different than a Toyota or Jeep boxed frame. Allow proper drain holes and coat inside of frame with protectant.
Thanks for the advice guys.
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've heard lots of good about Fluid Film [lanolin] yearly and some swear by spraying oil on the engine bay and underside every couple months. I've seen an applicator for inside body panels and frames that sprays at a 90degree to the wand and 360 degrees around. It's something I want to try on my racetruck.
