Bronco II Cowl Cover?
The Slider
Castroville, Texas
1972
Does anyone make a cowl cover for the Bronco II / Ranger to keep out the leaves?
Thanks!
Chaz
JerryC
56
Tennessee
I've thought about using magnetic Heat/AC vent covers, Lowes sells them 3 for ~6 bucks.
I ended up cleaning the garage and parking it in there.
85_Ranger4x4
17,908
SW Iowa
If you want to get wild the second gen have small holes rather than slots in the cowl...
Sean's84
8
BonnyDoon, CA
Bronco II
2.8l
When I had it parked under a couple of tan oaks, I ended up making some cowl covers using hardware cloth and some scrap sheetmetal. I had problems with oak leaves getting in and holding moisture against the inner cowl which is pretty typical. The mesh worked great to stop the big flat oak leaves.
Now I have the same issue with redwood duff, and when dry the stuff crumbles into tiny kernels, so the mod hasn't helped that as much. I put a tarp over the cab and cowl now since it works to keep both the duff out of the cowl and it stops the irritating leaks when it rains.
I also put mesh over the side vents behind the fenders since I was sick of having rats stuff the blower fan full of acorns. At least that worked to keep the rodents out (haven't had the acorn issue in almost 2 years, and for a while before I put screen over the vents, I was having to clean it out every month or so). So, small victories.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
