C5 to C4 trans conversion in Bronco II . . info
PetesPonies
25
east coast
2.3l
I have an '84 BII. It was an auto, so fortunately they came with a C5. When I went to a V8 in the truck, I changed the original C5 to a C4. That has been written about . . don't want to rehash the facts there. I did a standard 2 year swap :icon_rofl: Serious, this April is 2 years. I started two years ago, have been able to drive it for a while now, but mostly let it sit. The original C5 trans only had 59K miles on it and worked perfectly. When I first drove it after the engine swap, it worked fine, but the 2-3 shift had a flare that wasn't there when the 2.8 was still in the truck. I didn't drive it much . . wanted to figure out the problem. When I switched to an adjustable modulator, that helped. But still, it was a bandaid . . not right. The C5s have an "O" servo. I had an "A" servo here and made the swap . . finally. Well that did it. The shifts are perfect again. So I'm posting this because perhaps someone else will find this fix if they have a problem. Whether or not every C5 converted should/would need this mod . . . . not sure. But at least here is one situation that it did.
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks.
Richard
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
I hope you also put a C4 V8 valve body into it.
Yes, the "O" servo is cute. It needs at least an "A" C4 V8 servo.
PetesPonies
25
east coast
2.3l
What would be turning a C5 into a C4 if the VB wasn't changed???
RANGERROD
November 2012 OTOTM Winner
st helens or
Also bell housings are different and torque converters. Thanks for the info I'm having flare issues on my c5-c4 tranny. Guess its time to get a good servo.
PetesPonies
25
east coast
2.3l
Well sure the bell housing and TC had to be changed , going from a 2.8 to SBF. However, one piece of info I see a lot that is wrong is that the TC is a lock up type originally. No it isn't , not in the 2.8 truck application. Not that it makes any difference once to switch to SBF C4 components, but just something I see a lot that is inaccurate.
