Can't find this steering knuckle
Red October
4.0L OHV V6
My steering knuckle took a shit and cannot find one that has the vacuum line coming out of it .
scotts90ranger
4,524
Dayton Oregon
2.3 Turbo
I believe that would be a '98-2000 only thing with the PVH hubs, I believe after that they went away from hubs and went live with just the transfer case for a disconnect. I believe you can ditch those without too much issue.
Red October
4.0L OHV V6
Probably why I can't find any. I'm not even sure what to do or convert to get rid of this setup
scotts90ranger
4,524
Dayton Oregon
2.3 Turbo
Probably just complete hub assembly and CV axle at most, I don't know how the disengaging happened...
pjtoledo
3,015
Toledo Ohio
Fords
3.0 2.3
car-part.com has a couple hundred listed in the Midwest.
'99 RH
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
If you want to switch to the later '01-'11 live spindle setup, this might help:
Otherwise there also is this option:
There also is a way to work the PVH hubs manually by removing the outer cover part and cutting out the metal screens so it's just a hole. You then put your finger in through the hole and operate them not much unlike a click-type ballpoint pen (for some reason I'm not seeing a link to the article now :icon_confused: )
In all three cases this will negate whether your spindle has a spot for the vacuum line or not.
