Chopped Top B2 on Wagoneer chassis
crisd
37
Picture of the plate welded over the welded seam where the frame section was spliced. 14mm bolts will go where you see the holes.
crisd
37
If anyone has any specific questions I'd be happy to answer.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I had the entire chassis, engine, suspension, drivetrain dry ice blasted. Not worth it :-(
Why did you consider dry ice not worth it?
I have a very rusty pinto I'm going to be working on. Was considering ice, soda, and sand. I don't have personal experience with any. My racetruck was sandblasted but not the body panels.
crisd
37
I had watched some videos where the underbodies of a Porsche, an Audi and an old Ranger were dry ice blasted and I was impressed. Those cars had a lot of grime and crud that didn't wash off in the video but came right off with the dry ice blasting so I was excited to have it done. Not even half the crud was removed from mine and it still looked like crap. I believe I could have rented a steam blaster and got better results for a fraction of the price paid getting dry ice blasted. As far as rust, dry ice blasting will NOT remove rust. For that I would recommend the soda blasting. Sand blasting can easily warp body panels if not done properly but will remove a lot of material really fast. It will also create a LOT of heat so be careful.
crisd
37
So I can build my own roll cage or hit the easy button and order one... does anyone have any suggestions?
lil_Blue_Ford
6,216
Butler, PA, USSA
4.9L
So, I don’t know of any place to buy a Bronco II roll cage. Jegs does sell a Ranger cage which will fit in the BII, and that’s what I did with my choptop. I’m modifying it to meet what I want, IIRC it’s 1-5/8” tube though which seems to be a slightly odd size around here. Of course, none of the local Fab shops seem to own a tubing bender either for some strange reason. I bought my own bender and a 180* 1-5/8” die set for it so I can make what I need (JD squared model 32). Technically since I was buying the bender I could have made the entire cage, but what Jegs was selling the cage for at the time plus shipping was less than I would have spent buying all the steel locally, so it made sense to me to start with that and build from there.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If you plan on racing look at the rules for cages. Specifically the tube size. My class I need 1.75".
