coil spring spacer
pacepace87
i have a 95 ford ranger with a 6 inch lift and 3 inch body on 35'' tires. I want to make it even higher. I saw that you can use the factory f150 coil spring spacer and was wondering has anyone used it along with a daystar 2'' spacer?
daniel3507
74
NE Oklahoma
2.3 EcoBoost
if you go any higher you could possibly run into some steering issues
Smurf Mobile
Tucson AZ
3.slow
You would have to get new drop brackets for the I beams and radius arms, unless you have the skyjacker lift which may allow you to put them in the next hole down. If you really want that much lift you might as well get new springs, so you can ditch the Daystar and F150 spacers. With that being said the steering and alignment will be a nightmare and those 35's will start to wear out rather quickly.
Andrew
