coolant temp sensor
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Having a hard time getting this 1987 2.9 manual 5 speed to idle at the correct speed. I have discovered that if i disconnect the coolant temp sensor the idle drops and it revs up fine. When i disconnect it is drops 2 to 3 hundred RPMS. on restart is goes back up until i disconnect the sensor. Any help. thanks Dirty
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'm not great with the earlier trucks, but sounds more like an IAC problem. Unplugging the temp sensor puts it back in open loop mode, but if its already warm the engine is trying to "choke" it. Temp sensor is like a choke on a carb... when warm, it tells the engine to stop running rich, once warm it tells the engine to run normal. (These are called open and closed loop mode) The iac valve should be adjusting between the two modes.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
checked the iac valve. it open and closes just as it should.
