D35 replace threaded pinch bolt with bolt and nut?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Do you think I could replace the threaded pinch bolt on the D35 beam that holds the camber thingie (technical term) with a grade 8 nut and bolt? Would I be able to get enough pressure to pinch in the bushing? Refurbishing an old one and of course the pinch bolt is froze to the toes. If I have to drill it out I am just wondering if this would be a good solution?
Junk Collector
Truck of Month
4,839
Rapid City SD
You could... but probably easier to drill out the old bolt and clean up the threads and just use another metric bolt.
