Dash Swap?
fabman_52
Corbin Kentucky
1990 & 1987
2.9 & 3.0
HI All'
Can anyone tell me, what is the newest year dash that will bolt up to an 89/92 cab? Been told up to 98, just looking to verify. Has anyone done this swap and if so do you have any pix?
Thanks, George.
stegomon
20
auburn/minot maine
fords and only
any thing can work
locovaca
4
DeWitt, IA
A Gen 3 into a Gen 2 is not plug and play. The mounts are different, for one, not to mention the electronics are 100% different. Nobody has done it that I've seen around here.
stegomon
20
auburn/minot maine
fords and only
there is one guy on here that is swappin a 4.0 sohc in his gen 1...it can be done...if you are good at fab work
locovaca
4
DeWitt, IA
Yes, but you need to qualify your response. It's not as simple as bolting it in, there are a lot of things to consider on the eletrical front. HVAC is completely different (eletronic vs vacuum)- that's a biggie.
runningman
Washington
soon to be 302
I have a 97 ranger dash in an 84 ranger. I can be done but not for the faint at heart.
[/IMG]
A little info on the whole project.
The dashes are almost the same width so that was not a problem. I used the heater assembly out of the 97 and all the wiring from the 97. Tilt wheel out of a 99 explorer. I have an air bag too. I was surprised that the firewall in the newer truck was very similar, so making everything fit was not too bad. An automatic truck would even be easier. I used a newer brake & clutch assembly to fit under the dash. I did have to do a little cutting & welding on the upper firewall so the newer dash would fit tight up to the window. It actually looks like it belongs in there. I also used the gen 2 door panels to make it look a little nicer. It gave me delayed wiper control, AC capability, cruise control and a lot better electrical system as I used the entire electrical system off the 97.
177CIOfPureLove
Bayville, NJ
2.9L
Hey, runningman, what did it take to put gen 2 door panels onto your gen 1 doors? I noted that the handles were very different, are they in the same spot? I was looking forward to doing the same swap and was hoping it was as easy as swapping the handles and the panels, is it?
maverickwolfe
East TN, USA
x2 I wanted to know the SAME thing. I bought a 91 parts truck and would love to have that interior in my 88. Will it go in (plug and play)?
4.6StangRage
*BUMP* I am interested too!
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
I am looking at doing the same. Might get a 95 donor motor and want to swap the 95 dash into my 89. Need to get as much info as I can before I buy it.
v8-ranger
WA
The doors panels was actually simple i think i had to drill 3 holes total just take everything from the gen two and once your door is stripped on the gen 1 it fits right on. the holes need to be drilled for the new door handle and then the arm rest plate . The gen 1 door is set up to fit the newer handle slude right into place .
This is runningmans son.
OlBlue38
Lubbock,Texas
2.9 soon 5.0
I am about to start my swapping.86 Bronco2 97 5.0 Explorer AWD.REAR axle assy. any info and pictures would be appreciatd
Ramcharger90
1,708
N/A na
306, Bcam,
I gota get some measurements on this im gonna be doing this with a 98 mercury mountaineer into my 90 ranger found the merc with a 5.0 for $300 cant wait guess i need motor mounts and to flash the pcm a complete swap should be so simple.
