dual to one piece drive line swap
86freebie
suisun city, california
i just got an 86 ranger, the center u joint froze and ruined the yoke on the slip part of the long drive line. i read that you can do the drive line swap to a single drive line with minor mods. then at the bottom it says my year you need to "if you own a '83-'89 Supercab model, this swap can still be done, but the rear driveshaft flange on the axle will be smaller. You will need to swap the larger rear U-joint attachment with 3" bolt spacing with another forward one that has a 2.5" bolt spacing."can this be done with the parts from my old one?
kunar
131
Toledo, Ohio
5.8l
you should be able to, you may need an adapter style u-joint, i dont know for sure but someone here will....
your other issue is that if you have a manual you should have the fm145 which is like 2" shorter than the auto, so the driveshaft wont fit. if you have an auto, you should be good.
86freebie
ok after a good nights sleep i figured out what they mean by the swapping the flange,( i cant believe why it eluded me) i need to get out of axle that i am getting drive line from and put in mine. NOW i have replaced crush washer in a 84 ranger i had. i do know how to do it. i am not going through that again unless i have to. i.e. replace seal or gears. it is not that tough but it does require pulling axles (measure preload) having a way to hold flange while tightening. i do not have flat bar that was 4 feet long anymore. it is a long process. i think it took me 4 to 5 hrs on my 84. if anyone is changing something and have to take apart it is worth it while you have apart. as far as length with trannys i was hoping someone will answer for future reference.
86freebie
tranny length on drive line swap
does anyone know if there is a tranny lenght problem on a 2 pc to 1 pc drive line swap?
kunar
131
Toledo, Ohio
5.8l
figure out what transmission you have and go from there. for starters, is it a stick or an auto?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
1986
Stick = No workie
Auto = Fits right in
86freebie
thanx for all the help. went to two pick and pulls yesterday. no luck on just a drive line. found a new one on the web for 320. will check with a couple locals for getting 1 or getting a 1 pc made. i did buy super u-joints from napa. if i go stock i will throw those in.
and yes it is a manuel thanny. bummer
86freebie
local driveline shops
talked to a local drive line shop he will take apart fix and balance for what he is guessing at about 250 dollars. as long as just the slip yoke and carrier bearing are the only problems.:woot::woot:
kunar
131
Toledo, Ohio
5.8l
so youve got an fm145, its the same piece of junk im gonna be swapping out of my truck soon. if you arent having problems and want to keep that trans for a while, you may want to think of having a custom 1pc made.
:threadjacked:
Junkie: hey, that means that with an m5od in my truck, a 1pc will fit? even though ive got a 7.5 rear and not an 8.8?? ive never been able to get a straight answer to this, is the 7.5 and 8.8 the same length?
CJREX
8
N. GA.
2.3 EcoBoost
2.3
If you have the M5OD, the one piece will fit fine on the 7.5 rear.
I have done this swap on my '89 and the main things you have to do are:
change the yoke on the driveshaft to match the one on your rear axle,
Trim the gas tank skidplate. It will rub on the one piece driveshaft.
Excellent modification that totally removed my weird vibrations.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The axle flange side changed in mid-'90 IIRC, so any Rangers prior to that will need the smaller rear driveshaft flange (yoke) to fit the rear axle flange.
After that date, all axles (both 7.5 and 8.8) have the larger pinion flange (the pinion is the same length, yes)
kunar
131
Toledo, Ohio
5.8l
thanks guys! :clapping:
FatMike86
Roseville, CA
I'm going through carrier bearings like toilet paper. I'm gonna do the one piece swap; from what I've read I need a 98 or 99 supercab 4wd shaft...but my question is can I just take the crossmember holding the carrier bearing out? Or do I need it for structural support?
mkpecor
black diamond W.A.
ranger 4x4
if you do the one peace drive line you dont use the cross member with the carryer bearing toss it.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I'd keep it there (move it forward a bit for clearance if needed), although many do run without it with no issues.
BTW, if your truck is 2WD like your profile says, you need a 2WD shaft (from a truck with the same transmission as yours)
No members online now.
