Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
It's really up to you if you want the CAD. It will help in gas mileage, that's about it. If you plan on driving long distances and everyday highway use. Then I would keep the CAD. If you will have larger than 31" tires and want to wheel it hard, then you want to have a one piece axle instead of the disconnect. There are manual cable kits that do away with the vacuum actuator.Are those radius arms for a XJ or did you make them? I like the fact that you ran your brake lines along the link arms ,but where do they connect to the brake system that far back? I noticed no vacuum activator for 4WD on that D30,so does that one constantly turn the R&P? I have a D30 from an old 88 Comanche that I once owned that I will be using & wonder how I should go about eliminating the Vacuum activator & making it operate from a cable. Thinking of using the idle adjust cable system for semi trucks. I will be doing my SAS then later convert to 4wd. I already have the hardest item to find & thats the 2.3 4wd 5spd.
What transfer case are you using?
Thats ok, it's starting to grow on me. I have always like this generation better.hope you dont mind me sayin, but i like it better than the first one
