f150 axle in a ranger?
mn8814
what would i have to do to put a f150 rearend in my ranger. i broke my 7.5 axle in my ranger and its expensive to get somthing bigger out of another ranger. i have the f150 in my driveway and its about to be taken off the road so just wondering if it would work.
alaskan155
6
washington
FORD
7.3l/4.0l
weld new spring pads and shock mounts on the f-150 axle, its gonna be wider with a different bolt pattern than the front though
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
New spring pads run about 20 bucks from 4wheelparts. There's also an article on using square tube in the tech library.
Check on the size of your drive shaft U joints. You might need a conversion joint. I'm guessin around 40 bucks from dana spicer.
To make up for the wider rear, you could get spacers/adapters for the front and run the same lug pattern all around. If there's still a huge difference, some wheels with a different offset might do the trick.
What year is the F150? Might wanna take the front end too. (Depending on the year)
If your rig is a 4x4, make sure you've got the same ring gear ratio between the axles or you'll fawk your transfer case.
jlracing
new brunswick
2002 & 1989
ranger & bronco
4.0L & 2.9
My 02 fx4 blew her rear too and i can get an 8.8 with 4:10 gears from 1987 f150 with a 300 six 2x4. I have been searching on this forum and found this topic only. Sorry to hijack it but same questions I guess so hope it helps.
How much wider? I would think it would have the same drive shaft output plate. Must sell adaptors for 5.5 down to 4.5 or vise versa 4.5 to 5.5. Could play with spacers or offset wheel to equal out and a new set of fender flares would hide them.
sirgrizz420
to my knowledge a set of axles from a 1979 f150 will work for the ranger since they both have the same suspension set up just needs to be fitted to the ranger frame.
I have already started this project i"ll update with progress reports
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Ummm.....you brought up a 4 year old thread for this?
SniperJJ10
Maine
Ford Ranger XLT
Will a 90s 8.8 from an f150 fit under an 07 xlt?
MikeG
752
central Texas
B4000
2"
235/75r15
Too wide and wrong bolt pattern for wheels, same answer as 12 years ago.... ;)
GreenRanger090
8
Ohio
Ford Ranger XLT
I know its a bit of an old thread but I was wondering just like jlracing how much wider the 1992–1997 F150 rear end will be compared to the 1992 2.3L Ranger 2wd so i know the size for my fender flares and beams?
Josh B
1,988
Oklahoma
Why not get under there with a tape measure and find out? :) (I'm supposing you have a parts place to dig around in? )
rusty ol ranger
2.9 Mafia-Don
7,632
Michigan
177 CID
This might help.
From 73-86 the F150 was 65 inches (roughly)....im guessing 87-96 is in that neighboorhood..maybe exactly
Ranger (8.8) is 56 from 90-92. Going to assume the 7.5 is the same as the trucks were the same.
Either way its alot of difference to make up.
pjtoledo
2,995
Toledo Ohio
Fords
3.0 2.3
lets not forget Ranger axles are offset, wider on the drivers side. "choose wisely".
GreenRanger090
8
Ohio
Ford Ranger XLT
unfortunately not yet
GreenRanger090
8
Ohio
Ford Ranger XLT
This might help.
dang, 9s a bit much since 8 is what most bedsides are : ( , thx for the help, ill do some more research and then decide.
No members online now.
