I built my own this time around on my choptop. The first time I put it together I had a guy from the forums (redneckwelder) fab me up a set. They worked and they were cheap since he just used some spare parts and scrap laying around, but when it came time to put a D-35 under the choptop, I decided to do a new set of arms.
The first set worked but I had some tire rubbing issues with 33's, never got around to trying to tweak the arms to try to adjust for that. Also the D-28 shock mounts were not working out for the shocks I had and they were a PITA to bolt up since the back was plated. Rod ends were used for the frame mount end and I wanted something beefier that didn't require shims for freedom of movement. I also wanted to extend them slightly and to change the frame bracket design so that I could attach a transmission crossmember to it.
I looked around for awhile at different designs, the easiest and cheapest way to extend the arms is to use the stock bushings - just cut the end of the radius arm off with the stud, extend it with a piece of steel and stick the stud in the end of the steel, then make up a frame bracket to accept the stock bushing. Really it would work fine for all the travel that a TTB axle has. But mine were rusted pretty good and I wanted to go all out....
I bought some Ballistic Joints along with threaded inserts and jam nuts, prefab shock tabs, some 2x2x.250 tube, and some 1/4" steel for plating purposes. Then I did some careful mockup work, tacked it all together, took it out and welded it up and now I'm hoping that it all worked out, lol. You can check out my build thread if you want,
http://www.therangerstation.com/forums/showthread.php?t=128887
