Ford BBAS link
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Here is Fords Body Builders Advisory Service, which has the 2019 Ranger link to dimensions and layout in a PDF format;
https://fordbbas.com/publications
And a direct link to the PDF download;
https://madocumentupload.marketingassociates.com/api/Document/GetFile?v1=4567974&v2=110718032335&v3=60&v4=f557fc9d244d8ebb6bedaf95d28a009c6bcb1651275208a695506000&v5=False
RANGER
MODEL LINEUP
DIMENSIONAL DATA
SUPER CAB / CREW CAB
PICKUP BOX
SUPER CAB BOX DELETE
AXLE / TIRE / VEHICLE HEIGHT DATA
SUPER CAB BOX DELETE FUEL FILLER PIPE INSTALLATION
CHASSIS CAB / PICKUP BOX DELETE FRAME DATA
WHEEL & TIRE DATA
FRONT SURFACE AREA WORKSHEET
SEAT TRACK & H-POINT DATA
PICKUP BOX DELETE MAXIMUM UNLOADED VEHICLE WEIGHT
(UVW)
ELECTRICAL WIRING
CHMSL CIRCUIT
BOX DELETE TAIL LAMP
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,791
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
don4331
1,352
Calgary, AB
5.3
Thanks alwaysFlOoRed:
That doc provides a couple tidbits of information:
The wheels are 6 x 5.5; just different than the F-150's 6x135 that you can't swap/use F-150 aftermarket wheels.
And the interesting one for 85_Ranger4x4 and myself - the frame appears to be 3 pieces - front, rear and filler...
Which makes sense if you are using same frame for Ranger and Bronco II - you just shorten the filler/driveshaft/wiring...
But it also leaves door open for either SCab with 5' or 7' bed* or SCrew with 6' or 7' bed by just changing the length of the filler/driveshaft/wiring. (I'll need some better reconnaissance on whether the rear frame is different between SCab and SCrew).
I wonder how pi$$ed the wife will be if I cut the frame the 1st week I have a new truck?
*7' bed would need to be imported from overseas but not impossible.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
mine already gave me permission....:shok:
:dunno: who knew...
