If you want you can gap plugs a little wider, +0.003, above current gap, which is better for startup, but worse for RPMs above 3,500, if you run it that high
Current gap is 0.044" so change to 0.047"
Wider gap makes for a hotter spark for start up but also less time for coil to recover between sparks, which is why its better for start up but "less better" for high RPMs, lol
Narrower gap is "less better" for startup but better for RACING!
Vehicle makers pick a gap in the middle, so you can use +/- 0.005" if you want, kinda like the tire pressure thing, your tire so use the pressure you want
If ECT sensor tests at under 1volt warmed up then computer is most likely the issue especially if you haven't got lean or rich codes coming up
+1 on Uncle Gump, heads up on ANY "new" part, new used to mean "tested and working", new now means "YOU TEST IT, and we will replace it if it doesn't work"
If you can test running fuel pressure and its 30-40psi that OK, the fuel pump can do 80+psi, which is why it needs an FPR
While its a long shot, a return fuel line can get kinked or restricted, causing high fuel pressure, so if possible take that off the table with a test
