kxri318
- Jan 31, 2023
- 28
- Ohio
- Ford Ranger
The injectors on my 1986 Ranger 2.9 are definitely leaking, but it seems like barely leaking. When I jump the fuel pump with the injectors not even plugged into the wiring harness, I can see a tiny bit of fuel coming out of the nozzle and everything gets a bit coated in gas and shiny. Not sure if this amount is normal, but it doesn't seem like enough to cause my truck to flood itself after maybe 3 tries cranking it and also getting 8.5ish mpg (when it didn't run so bad it could actually drive). The rich running also got worse over time, starting from 11-14MPG and starting good + running rough, to 7-10MPG and starting rough + running rough, to struggling to start at all. My fuel pump seemed to be making some weird noises too. The sounds are closer towards the front end.
I attached a picture of an injector after wiping it dry then turning on the fuel pump for maybe 6 seconds
Do you think these injectors are just old and bad or is that normal to see a small amount of gas? It seems like all of the injectors are doing this, but some seem worse than others.
