Fuel Pump Question
Scott B.
EMT / Paramedic
Georgia
'93
My '93 needs a new fuel pump.
Looking at RockAuto, I see a Motorcraft pump assembly for $262, and a Delphi assembly for $75. What makes the $200 difference?
What are good brands to buy, and ones to stay away from.?
When I did the V8 swap, I learned there was a difference in cheap parts and Motorcraft parts. Same logic here?
Thanks.
8,388
Motorcraft parts are tested after being manufactured and before being boxed.
Its the Quality Control that is required by Ford, they also require "origin" documents of anything IN the Ford part
They can't afford putting in untested parts into new vehicles, costs them too much down the road with warranty labor and customer satisfaction
So they just pay the labor up front to test parts
For 3rd party brands, YOU are the Quality Control Department, YOU test it, if it fails under warranty "they" replace it, but YOU supply the labor to swap it out
For easy to get to parts, 3rd party are fine to used, IMO, not a big deal to swap them out
Fuel Pumps are a judgement call as far as labor to swap them out and distance from "home" if a 3rd party pump should fail
If you do alot of out of town driving I might just pay up front for Motorcraft to avoid a towing bill, or the inconvenience, of swapping pumps on the side of the road
If you decide on 3rd party pump see if you can find one with warranty that rolls over, i.e. if it has a 12month warranty and it fails at 10 months, then the "free" replacement ALSO has 12 month warranty from when you get it, not just the remaining 2 months
4x4junkie
585
So. Calif (SFV)
2.9L V6
35x12.50R15
I bought a Carter brand fuel pump for my '94 years ago... Best I could tell, it was 100% identical to the OEM pump, just didn't have the Ford oval stamped in the side of the motor housing. My guess is Carter (or whoever makes this particular model pump for Carter) is also who makes pumps for Ford. Cost was around $130 IIRC.
I've heard Bosch is also good (I've no personal experience though). Never researched Delphi, but $75 does sound awfully cheap to me.
Whatever you get, make sure it's manufactured in USA.
Scott B.
EMT / Paramedic
Georgia
'93
Thanks for the replies.
I decided to get the Motorcraft one - it's a lot of work just to have to do it again.
