Help asap
Bulldog666
Colorado Springs Co
Mazda (AKA Ford
can someone walk me trough this. i have a 1998 Mazda B 4000 (same as Ford ranger) Extended cab, where the extension acts like a door. someone came along and busted out the drivers side door glass front (not the one on the cab extension but the door) it has power windows. first would glass from a crank up work? there is a u pull and pay junkyard close to me so i could pull the glass from one. walk me trough it please.
fangotango306
8
sc michigan
None yet
It should. As far as i know. Door glass is the same whether its manual or power.
Denisefwd93
74
South East PA
It should be the same on crank or electric because the glass has two big plastic washers that hold it in place you will need a cordless drill a sharp chisel and Hammer and good drill bits to drill out the quarter inch aluminum rivets that you can replace with bolts and lock nuts,. we did both motors on my truck but it's all essentially the same work, check out the video
https://youtu.be/Ntr5pwWROjo
No members online now.
