Wanted HELP! Fuel lines
11
In desperate need of the fuel lines for a 1990 BII from the frame rail, to the fuel rail. I need to style with quick connects on both ends. Don't have a yard near me with a BII or second gen ranger on the yard. Pulled a the motor from a parts vehicle for a project, and stupidly sold the parts before completing the project.
alwaysFlOoReD
5,100
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Where are you?
8,370
Rangers use 5/16" nylon fuel lines, but use 3/8" connectors and 5/16" connectors
3/8" connectors on IN from fuel pump
5/16" connectors on RETURN to gas tank
Dorman sells the quick connect fittings
Engine bay fuel lines did have steel mesh because of possible damage from tools or exhaust heat
You can buy lengths of 5/16" nylon steel mesh fuel line and then cut to length and install the fittings
11
One is the springlock, ans the other is the female side. I could make the one going into the rail work, but would need a female end for the regulator side. In their fuel line connectors, Dorman does show the springlock connectors, but not the remale ends.
On top of this, I was really hoping to find someone with the factory lines that I could just pop in at the frame, and pop in on the motor, and be done with it. I get about 16 hrs in a month's time to work on this project (suck it 12hr rotating night shift), so making new fuel lines is gonna set me back literally a half a month.
scrapper
63
central IL
1975 302
Are they like the lines in a 94? A wide one?
11
Think I got something figured out.
