Rangers use 5/16" nylon fuel lines, but use 3/8" connectors and 5/16" connectors
3/8" connectors on IN from fuel pump
5/16" connectors on RETURN to gas tank
Dorman sells the quick connect fittings
Engine bay fuel lines did have steel mesh because of possible damage from tools or exhaust heat
You can buy lengths of 5/16" nylon steel mesh fuel line and then cut to length and install the fittings
One is the springlock, ans the other is the female side. I could make the one going into the rail work, but would need a female end for the regulator side. In their fuel line connectors, Dorman does show the springlock connectors, but not the remale ends.
On top of this, I was really hoping to find someone with the factory lines that I could just pop in at the frame, and pop in on the motor, and be done with it. I get about 16 hrs in a month's time to work on this project (suck it 12hr rotating night shift), so making new fuel lines is gonna set me back literally a half a month.
