How many miles on your 4.0?
racsan
4,499
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
im at 112,000 on a '93. it had 60,000 on it when i bought it 4 years ago. someone in the military must have owned it, had a windsheild pass for peterson a.f.b. and a colorado dealership badge on the tailgate. looks real good on the outside but plenty rusty underneath. runs real good, had to put intake gaskets on it last spring. gets 19 at best 15 in the winter and about 12 with this high-roof trailer. i should upgrade to a 1/2 ton or bronco. but this is paid for and will get the job done.
________
digital vaporizer
phybere
181k on my 4.0, and it leaks oil like a sieve (anybody else noticing oil leaking directly through the valve covers? :dntknw:)
PL1993
Are your valve covers rusted through? I had a valve cover gasket leaking a couple of years ago. When I fixed it the cover looked a little rusty. I have seen a couple of Ford oil pans from the mid '90s rust through.
94STXRanger
Kansas City
4.0, 302
113k on my 94 4x4. Coolant is murky, rusty i think, need to flush it. Ticks under heavy acceleration. Runs good though.
ZSK
Jacksonville, FL
5.4
That picture looks quite similar to my setup. I'm at about 214K. It's leaking a bit of oil around the valve covers but not bad, I'll get new gaskets soon. With 29" all-terrain tires and 3.55 gears I saw 24 mpg consistantly. I'm hitting about 17-18 mpg with the current setup.
This one got a low of 8.5 mpg and a high of nearly 15 mpg on the move from Michigan down to Jacksonville, FL mileage got better the further south I went.
Royawest
Northwest PA
Mazda
My 94 B4000 has 154,000,runs great,replaced intake gaskets,egr sensor.doesn't smoke has slight valve tick on cold start but runs great.
Black_Splash
Huntingburg, IN
I've got 178,000 give or take here.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
33k currently on the Ranger 4.0 SOHC
163k currently on the Explorer 4.0 OHV
Culprit
Fredericksburg, VA
218,000 miles on my '95. New alternator, power steering pump, idler pulley, carrier bearing (extended cab - two piece driveshaft), wheel bearings, fuel pump, etc... nothing major and she's been paid off for years.
Doesn't use any oil, but I'm starting to notice a little seeping from where the oil filter mounting bracket bolts to the block. I suppose I need to look into that.
I bought her in '98 with 50,000 on the clock. As they say, she doesn't owe me a dime.
mazzman
San Diego,Ca
52k on my 04, i love it, need to change rear end gear for more power for climbing hillss/towing tho
ashleyroachclip
1994 Ranger STX
1995 Explorer L
94 STX 4x4 , super cab , 364K .
I've replaced 2 injectors , and just done routine maintinance (can't spell).
I bought the truck from the original owner , 4 years ago .
It had 150K then .
Doesn't use oil , runs like a top .
crazywhiteboy
May 2011 OTOTM Winner
clearlake, ca
just rolled over 217k. had it since 206k. everything original cept for front coils, and "lincoln" locked front. broke first axleshaft today in the snow. anyone know where i can get a new set for the front? possibly stronger?
rangergt89
S Oregon
145K on my 91 Explorer
BlaineM
south central Ontario
254,000 miles or 407,000 kms on my 97 and I'm sure its good for many more.
