ekrampitzjr
- May 28, 2021
- 1,079
- Virginia
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
To replace the turn signal relay on my 2011, I was able to reach above the OBD port and feel where the relay is (I think). There really isn't enough room to work.
I want to remove the plastic dash panel under the steering wheel and the metal panel behind it to be able to see and reach. My question is, how do I disconnect the hood latch lever from that plastic panel? Removing the two 7 mm-hex screws on the bottom of the panel and popping loose the fasteners isn't enough to free the panel. It's still fastened in some way I cannot see around the latch lever. I don't want to break anything, obviously.
Thanks!
Thanks!
