hydraulic hoses
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I have a 1990 truck. I don't know if the hoses have ever been replaced. Should they be changed just because they are old?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,684
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If they aren't cracking, splitting, or leaking, you don't need to. I wouldn't look down on you for doing it. Absolutely nothing wrong with doing preventative maintenance and brake hoses aren't expensive. Just make sure you have wrenches made specifically for brake lines. They look like a box end wrench with a notch cut out of the end.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,493
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Not sure about the rust factor in NC...
In my neck of the woods... every brake line and hose would have been replaced probably 10 years ago.
All the rubber hoses in a brake system degrade over time... yours are nearly 30 years old... I think it's probably time
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I think I'll go ahead and change them. Of course since I'm doing that I might as well change the front pads, the anti skid module since the light has been on forever and a brake part mounted on the rear of the left front fender is leak ing so that should be fixed too.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Yes. Fix all brake related issues. :icon_thumby:
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
Ok, I"m going to change everything. Should I bleed the lines before I change the ABS pump so that the old fluid doesn't get into the new pump? Or change everything and bleed at each wheel?
sgtsandman
Ham Radio Operator
12,684
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Change everything and then bleed. You are going to be introducing all kinds of air into the lines and any old fluid will get flushed out when you bleed the lines.
Uncle Gump
Token Old Guy
13,493
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I don't think you actually have a an ABS pump... I believe what you refer to is ABS Modulator but I see it listed at advance auto as an ABS hydraulic unit. No pump... just solenoids to divert fluid if it senses rear brakes locked up. Use a little care when removing the line nuts from that unit if possible... I believe those are bastard size and you may have to reuse them when making new lines.
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
Thanks, to all of you. Your help reduces my worry.
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I changed the hoses, pads, and the hydraulic unit. I bled the system and now the brakes work as they should. But, the two little brakes lights now come on and the Rear ABS brake light still comes on. What to do? Should I change the wheel speed sensor, ABS Control Mod., or what?
Throw the light bulb away, it's clearly defective.
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I think you're saying it doesn't matter. I changed the hydraulic module only because it was leaking
