Infamous mazda the $200 mazda build
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
There is the relocated tailgate handle.
GriffinM6
ASE Certified Tech
4
Chehalis, WA
Ford Ranger STX
2.9
2 inches
235/75r15
Very impressive work can’t wait to see your final product
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Just a few pictures of it as it sets now. Still doing body work on the bed and tailgate.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
So I was going to drive it a couple months get a good feel for how it runs. Then continue with building the suspension and doing any more modifications. Remember this truck was sitting out in a field for years when I got it. I drove it around the past several days and now I have no power steering, no brake lights or highbeams. Horn isn't working either. So a few minor setbacks I have to work on before I get it on the road.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Started cutting out the front suspension to put the bags on the front. Got the sway bar out, coil springs out, radius arms are disconnected. Shocks out. Ran it up as much as it would go.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Put the wheel on for a test fit. Still have to notch the frame for the tie rods and remove some of the inner apron for the tire to tuck more. Then I will weld the bag brackets in.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Bag Brackets welded in on passengers side and the tie rod notch welded on. There was a big hole in the frame above the tie rod notch so I cut and welded a plate above to strengthen it. Radius arms are relocated above the frame rail with new bushings. Not exactly sure what im gonna do on the brake line just yet. Sprayed everything with a coat of black paint for now to keep it from rusting. Had to remove the factory air box for clearance so i have to buy or make a cold air intake. Have to adapt maf sensor to the new intake.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Looks like it will work. Did you round the corners on the fishplate? Its hard to tell in the photo. Square corners promote stress cracks.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Yes rounded comers.....i dont like welding to points and stopping when I plate things.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Had to pull the factory intake for tire clearance. Had a universal cold air kit on a shelve tucked away. I had to make an adapter so the maf sensor would work with the intake. Cut some pieces and welded it up. I put rtv around the weld just to make sure it was sealed good not pulling air through any possible little void. Not the prettiest, but it works and really wont be seen anyway. I will try and get a pic with the whole intake on there soon.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
There is the intake. Still have to hook up one vacuum line. I will need to figure out a radiator overflow. Not bad for some welding and some stuff I already had laying around though.
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Use the stock connections. Just slightly modified
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Finally have front suspension finished. Here it is layed out in front. Still need to build a raised tranny crossmember to let sit down another couple inches
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
I like how it turned out. But it is the first and last time I will ever put air suspension on an I beam truck. Not worth all the time it took. I think clipping the frame is a much better idea in the long run.........
Infamousmazda
59
Marshall tx
Mazda B2300
Air ride
Just a few pics of it as is out of the shop for the first time. Had to make room in the shop to paint a truck so thought I would take a few pics while this one was out in the daylight again. A work in progress for sure, but it has come a long way.
