Wanted Intake for 2.8 V6 2 bbl. Carb
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
Looking for a stock intake manifold for the 2.8 liter V6. Would prefer something in Good+ condition. Willing to purchase outright or trade parts.
Thanks.
Bronco648
102
XL
2.3
15"
Green Sales has two of them, new old stock in the box. E3TZ-9424-D.
Thanks Andy, I sent them an email requesting pricing + shipping. You don't happen to work there, do you...? ;)
gaz
682
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
AndyB.
147
Cincinnati, OH
I don’t work there, but I’m on a first name basis with them—I’ve bought a lot of parts there.
When I looked at one of these a few years ago, it was the older style with the thermostat housing in the lower front cover. The later part number is E5TZ-9424-E. I’m still on the lookout for an NOS one of them.
Bronco648
102
XL
2.3
15"
I had noticed that you were in Cincinnati, like they are. :)
IIRC, the t-stat is in the timing gear cover. So, there's two different styles?
ford4wd08
513
Alcoa, TN
2.8 V6
Yes, sometime in mid ‘85 the thermostat was moved to the top of the intake manifold. The bypass hose connects to the upper thermostat housing rather than the intake. Pictured, is the later style.
Always wondered what it looked like. My early 85 has the other style.
Bronco648
102
XL
2.3
15"
Thanks @AndyB. I checked the VIN Sticker and my truck was made in September of '84. My water neck is different and when I tore the old engine down, the t-stat was in the timing gear cover.
But, if there's a special t-stat housing for the water neck, how does that change the manifold such that there's an early and a late version?
Bronco648
102
XL
2.3
15"
@AndyB. So, are those two parts used in conjunction with each other? I'm having a hard time visualizing this.
Also, why does there seem to be two water temperature sensors?
AndyB.
147
Cincinnati, OH
It’s the same part, different views. There thermostat goes inside, another pieces connects to that housing and the upper radiator hose.
There’s a coolant temperate sensor (two wires) goes to ECU, the other sending unit/switch goes to the gauge/warning light.
Bronco648
102
XL
2.3
15"
So, if I'm going to switch to the Duraspark ignition, then one sensor won't be connected?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,631
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If you're scrapping the ECU... you won't need the two wire ECT sensor.
Bronco648
102
XL
2.3
15"
Intake found. Thanks all!
