Lift questions and identification
Skooby
34
Oregon
Bought a parts truck that has a what I was told was a 4" lift on it. Can anyone identify the brand? Also were the 4" lifts for this Era truck a lift/level kit? I ask because it looks like the blocks for the rear are only 2-2½ taller that stock?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Looks like a Tuff Country kit (they had the camber eccentric bolts at the axle pivots).
Not the strongest kit, but it's fairly decent (and won't bust open your front differential housing like some others will).
Most suspension lift kits will raise the rear an inch or two less than the front. A "leveling" lift typically lifts the front 2" or so, without touching the rear at all.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Suspension Connection has the same brackets and adjustable Camber pivot bolts pictured above. I know that their 4" lift kit keeps the suspension level, at least the one I installed in my truck.
Skooby
34
Oregon
Thanks will be pulling and installing on my kids truck this week we did the rear last night. Then onto the custom front bumper!
