LS swap! finally
rumblecloud
1,133
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
You people scare me...o_O:p
Mackhedq
146
minnesota
If youre gonna be dumb you gotta be tough
Just another steering update now. Also got a lead on some 35s, going All Terrians just to keep road noise down. Planning on finishing out the exhaust from the bumper and need to put 4wd shifter in. Steering update below, working on tierod arms. Nearly able to keep them perfectly straight. Full steering lock to lock from full bump to droop.
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Probably the angle of the pic, but it looks like the Ackerman is wack.
Mackhedq
146
minnesota
Just the .7 lense and caster at full bump. They'll maintain a correct angle. Both arms are perfectly mirrored and the same lever length.
Mackhedq
146
minnesota
So so so close now. Lost a little travel with the 35s but well needed. Steering is all in place just need a lot of bracing now.
Mackhedq
146
minnesota
Steering is almost done. A couple Misalignment spacers on back order and need to finish center link up.
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Looks like the arms weren't moving exactly same. That's what the spacers are for?
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Congratulations! That first start after a swap is always a special moment. :cry:
