Marine 2.3 Difference
Lanes dad
Otter Lake MI.
Hi Guys new here to the group is there any difference in the marine 2.3 than a truck model 89 yr performance wise
8,372
In the late 1980's Ranger 2.3ls went from 4 spark plugs with distributor to 8 spark plugs and no distributor, but the engine was the same except for the extra spark plug holes which could be blocked off
Distributor hole was still there until 1995 I think
So yes you could swap in a Ranger 2.3l engine and bolt the boats intakes and exhaust to it
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
The marine version, to my knowledge, had a carburetor and a slightly different cam. Don't bet the farm on the cam being 'performance' as what you want with a marine application is immediate 'grunt' to twirl the prop.
If you have a broken marine 2.3, you should be able to swap cams as desired. You may be able to detect a different grind. The cam could have a manufacturers part number if it is not a FoMoCo designed/produced part.
If you like, you can use a roller cam follower cam and followers and gain some hp/torque. Again, grind may be different.
I did fiddle with one that had stumble problems when the throttle was pulled wide open from an idle. Carb accelerator pump needed to be 'fattened' as I remember.
tom
