My rear end locks up in 4x4
Ryle_Smartlowit
Washington State
My rear end locks up when I'm in 4wd and when I come to a stop or slow down is when it will lock up, But if I take it out of 4wd and back the truck up then go forward it be just fine. My rear end is a ford 8.8 with LSD and disc brakes. Any help or advice will be greatly appreciated.
gw33gp
Ham Radio Operator
549
Costa Mesa, CA
4.0 SOHC
33"
How do you know it is the rear end that is locking up?
alwaysFlOoReD
5,166
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ good point. When the transfer case is engaged - the 4x4 is on - then the front and rear axles are tied together. You have symptoms of something wrong with forward of the transfer case ie; front axle possibly.
gandrimp
A 94 with disc brakes also indicates an axle swap, are the ratios the same?
hondaxr650
4
Tacoma, WA
My first thought too. Sure sounds like it has 2 different axle ratios...
Big Jim M
30
Austin
I agree! Backing up UNWINDS the system allowing the 4x4 to be released. I bet he didn't get very far in 4x4!
I would suggest jacking up one front wheel and one back wheel and then turning them to see just what is inside each pumpkin.
Big Jim
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Thanks for posting a follow up :D
Ryle_Smartlowit
Washington State
It's the brakes and my front diff gears done
