lordkyleofearth
- Jan 7, 2010
- 0
- Boerne, Tx
- 97/95 hybrid
- FORD
- Engine Size
- 2.3
I've had a short love/hate relationship with my ranger. After a rough start to our time together, it now has a rebuilt bottom end (rings, bearings, seals, gaskets) and a few electrical issues (O2 heater circuit fault). However it recently started having a new problem, and I can't figure it out.
After I start to reach the upper end of my daily RPM range (not sure where exactly, the tach has never worked) the engine starts to bog down and miss-fire. This has effectivly limited the truck to a max speed of ~55mph which is down right dangerous on the Texas freeway system.
It seems that the longer I drive, the worse it gets (the dead zone drops to lower RPMs) and some times when I go to start the truck it will crank but never catch. This can be remedied by disconnecting the battery and cycling the lights.
It sometimes backfires a bit so I figured the plugs were fouled (from running rich) and so I pulled them and they are white (which indicates lean running correct?) I installed new Autolite double platinums (gapped 0.44) and the problem persisted.
It all started after I filled up at a different gas station, and seemed to get better after I topped off with some 93 octane, but it has sense returned so I'm starting to suspect gas is not the problem.
I know that my O2 system has a fault in the heater circuit, but it has always had that fault and this problem only started a few days ago. Any ideas? I commute 45mins a day along road with no shoulder, so I really want to get this sorted out before I am stranded blocking 80mph traffic.
