Need help determaning if I have a bad rotor or cap or distributor.
Bolts-N-Nutz1987
Newberg Oregon
3.0 Liter
I have replaced the cap rotor plugs cables 2 months ago and my truck still has a problem starting. I know that my truck has an issue starting after some time siting off. The only way I can get it started is to spray starting fluid into the intake manifold. I have not replaced the distributor since I've owned the truck its got 190,000 miles. New injectors cables plugs cap and rotor. Less than 5,000 miles on it. Any help is great.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Sounds more like a fuel related issue to me. I would get a fuel pressure gauge on it and ensure the fuel system primes properly when you key on before starting.
I agree, if it starts fine on starting fluid it isn't a spark problem. Spark works the same on gas or ether, so you have a fuel issue. It's probably bleeding the pressure off back into the tank and not getting primed well enough before you start cranking. I'd be looking at the fuel pump at this point.
rusty ol ranger
2.9 Mafia-Don
7,593
Michigan
177 CID
Try cycleing the key 4 or 5 times before you start it.
Bolts-N-Nutz1987
Newberg Oregon
3.0 Liter
I bought a new pump 2 months ago. I changed the Fuel filter and still am having problems.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
try replacing the distributor, everything else seems new. still seems like a fuel issue and not ignition. are your injectors leaking or clogged?
Uncle Gump
Token Old Guy
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
"New" doesn't mean "works properly"
I still say put a fuel pressure gauge on it... it is the only way to determine if it "works properly".
Bolts-N-Nutz1987
Newberg Oregon
3.0 Liter
No but the smell of fuel is reaching mybtruck cab
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Then you are definitely losing fuel/pressure some where. If it is getting into the truck, I would start looking in the engine bay for a puddle or drip. Starting at the rails and going backwards.
