NEED HELP! O2 sensor wire
powershiftfive
Breinigsville, PA
Ford Bronco II
somebody stole the exhaust system off of my 1989 Ford Bronco II. When they did, they ripped out the wire for the oxygen sensor. I can’t find it anywhere. even a small piece. Could somebody please help me locate where it is on the wiring harness? pictures would be extremely helpful.
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Passenger side a black wire casing runs along the intake manifold. When it reaches the back of the manifold 3 smaller black casing come out. One to distributor one to O2 and I’m unsure of the other. Maybe transmission.
In the picture it’s the one closest to the valve cover. It has a disconnect then pigtail to O2
powershiftfive
Breinigsville, PA
Ford Bronco II
thank you! thats a great start.
in the picture can you circle which of the 3 wires goes to the O2 sensor?
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I circled the casing that has the O2. The arrow points to the O2. You can see the pigtail following the exhaust up to the connection.
