- Feb 28, 2001
- 4,374
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
Transfer case is bolted on finally, it's a tight fit!!! Shifter is bolted to transmission just need to make hole in floor bigger then figure out the boot and get the lever on... then bolt on rear driveshaft... also need to get the trans dipstick tube bolt back in, fill it with fluid then get the motor mount finished up...
Should be driving this weekend, I can skip some things for a while like getting all the 4x4 components working
